Mostra risultati per tag ' getti'.
ROMPICAPO P200E NON PARTE A CALDO!!!!
SFOAMOTO ha pubblicato una discussione in Tecnica Generale: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
SALVE A TUTTI HO GIA' SCRITTO IN UN'ALTRA OCCASIONE SU QUESTO FORUM PER DEI PROBLEMI DI GRIPPAGGIO DEL 208 POLINI CHE GRAZIE AI VOSTRI CONSIGLI SULL'ANTICIPO E ALLA TESTATA SONO RIUSCITO A RISOLVERE, MA ORA MI E SORTO UN NUOVO GRAVE PROBLEMA: LA VESPA PARTE BENISSIMO A FREDDO, MA NON C'E' MODO DI FARLA PARTIRE A CALDO... POSSO PEDALARE UN'ORA O SPINGERLA PER 2 KM, MA NON PARTE IN NESSUNA MANIERA, A VOLTE SEMBRA CHE FACCIA UNO SCOPPIETTO, MA NON PARTE. SEMBRA INGOLFATA, MA CHIUDENDO LA BENZINA, TOGLIENDO LA CANDELA, GAS APERTO E PEDALANDO COME UN MATTO, DOPO NON RIPARTE LO STESSO, QUINDI NON CREDO SIA INGOLFATA. HO UN GIGLE' DI 130, HO PROVATO AD AUMENTARLO, MA NON CAMBIA ASSOLUTAMENTE NIENTE. IL FRENO ARIA E' 185 L'EMULSIONE BER4 E GIGLE' COME HO DETTO 130/135, IL FILTRO ARIA E' NUOVO CON I 2 FORELLINI NEL CUORICINO SOPRA I GETTI DI MAX E MIN, ANTICIPO E' CIRCA A 17 GRADI (SOTTO LA FAMOSA TACCA IT), LA CANDELA E' UNA CHAMPION N2C (MOLTO FREDDA) MA HO PROVATO A SOSTITUIRLA CON ALTRE 3 CANDELE SEMPRE PIU' CALDE MA LA VESPA NON NE HA VOLUTO SAPERE DI PARTIRE!!!! CORRENTE LA DA PERFETTAMENTE. L'UNICO MODO DI FARLA RIPARTIRE E' TOGLIERE IL FILTRO DELL'ARIA E ALLA PRIMA PEDALATA LA VESPA SI METTE IN MOTO SUBITO. RISPENGNENDO LA VESPA RIMONTANDO IL FILTRO E LA PUPPA DOPO PARTE PERFETTAMENTE. QUESTA E' UNA COSA CHE MI E' CAPITATA CIRCA 10/12 VOLTE E TUTTE LE VOLTE SE NON TOLGO IL FILTRO E LA METTO IN MOTO SENZA DI ESSO NON C'E' MODO DI FARLA PARTIRE!!!! HO PENSATO DIVERSE SITUAZIONI, MA NESSUNA MI HA CONVINTO PARTICOLARMENTE: 1) LA VESPA SI INGOLFA PERCHE' LO SPILLO DEL CARBURATORE NON CHIUDE BENE! - NON PUO' ESSERE ALTRIMENTI ANCHE A FREDDO DOVREBBE DARE PROBLEMI - 2) LA FASE DEL MOTORE E' TROPPO RITARDATA (17 GRADI)! - MA GLI ALTRI VESPISTI NON HANNO IL MIO PROBLEMA- 3) IL GIGLE' DI 135 E' TROPPO GRANDE! - HO MESSO IL 130 E NON CAMBIA NIENTE 4) IL PARAOLIO LATO FRIZIONE CON IL CALORE DEL MOTORE SI DILATA E PRENDE ARIA! -IL PARAOLIO E' NUOVO ED HA 200 KM, E' DI QUELLI CON IL PIATTINO TUTTO IN LAMIERA E NON PUO' NEMMENO USCIRE DALLA SEDE- UNA SOLA VOLTA ANCHE AVENDO APERTO IL FILTRO DELL'ARIA DOPO HA DATA ANCORA PROBLEMI, E' PARTITA MA ANCHE A TUTTO GAS LA VESPA E' RIMASTA AL MINIMO PER CIRCA 30 SEC., COME SE NON ARRIVASSE BENZINA, POI SI E' SPENTA. IL CARBURATORE E' PULITISSIMO, L'HO ANCHE RIAPERTO 2 VOLTE E TIRANDO L'ARIA (LO STARTER) NON CAMBIA ASSOLUTAMENTE NIENTE.....NON SO COSA FARE, NON MI ERA MAI CAPITATO UNA COSA DEL GENERE.......AIUTO. SALUTI E GRAZIE A TUTTI. SFOAMOTO -
getti DR 177
paopao ha pubblicato una discussione in Elaborazioni: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
amici , ho montato un DR 177 su un PX 125. non ho fatto altre modifiche, che getti devo montare? grazie -
Scatalizzazione PX 150: getto max 100 o 102?
matteo70 ha pubblicato una discussione in Tecnica Generale: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Ciao a tutti, sto per scatalizzare il mio px 150 del 2000 e ho letto le varie discussioni a riguardo sui getti. Mi rimane un dubbio: il getto del massimo deve essere 100 o 102? Il px e' un 150 euro 1 con miscelatore. In alcuni post ho letto che si deve mettere 100 per vespe con miscelatore e 102 per vespe senza, ma qualcuno suggerisce invece il 102 sempre. Un consiglio? Grazie, Matteo -
E' consigliabile un px 200 con miscelatore o è meglio senza? Ne ho visto uno del 1980 che ne è sprovvisto e prima di muovermi vorrei capire se il miscelatore è veramente un valore aggiunto. Grazie
I getti per i carburatori SI
maxxx ha pubblicato una discussione in Tecnica Generale: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
... riassumendo e prendendo per buona la seguente tabella per i PX: e quest'altra per le vecchie: Partendo dal concetto che il valore del passaggio aria è lo stesso sia per il getto massimo che per il minimo... I valori di partenza dei seguenti modelli di Vespa sono: T5 pre '86 SI 24/24G - Getto max: 100 BE4 114 (112 mix) - Getto min: 100 50 T5 post '86 SI 24/24G - Getto max: 120 BE4 110 - Getto min: 100 50 PX125 MY catalizzato SI 20/20D - Getto max: 140 BE5 96 - Getto min: 140 45 PX125 MY scatalizzato SI 20/20D - Getto max: 140 BE5 100 - Getto min: 140 45 PX150 MY catalizzato SI 20/20D - Getto max: 150 BE5 98 - Getto min: 150 50 PX150 MY scatalizzato SI 20/20D - Getto max: 160 BE3 102 - Getto min: 160 48 SV SI 20/20D - Getto max: 160 BE3 102 - Getto min: 160 48 GL SI 20/17D - Getto max: 160 E1 100 - Getto min: 160 42 (starter 60) Link sul colore delle candele... Spark Plugs -
Proma su et3
freerider67 ha pubblicato una discussione in Tecnica Generale: Telai Piccoli (ET3, PK, Special, ecc.ecc.)
ciao a tutti, ho una et3 tutta originale con shb 19/19 vorrei mettere la proma , lascio i getti come sono o devo aumentare il massimo? grazie anticipatamente. -
Getti Carburatore 24/24
Peppe99px ha pubblicato una discussione in Elaborazioni: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Salve a tutti. Ho un carburatore 24/24, con getto max 160 e getto min 59-120, da mettere su un dr 177. I getti mi sembrano TROPPO grandi, qualche consiglio?- 10 risposte
- carburatore
- getti
(and 1 più)
Taggato come:
Aiuto....carburazione 102 dr carburatore 19/19
pauloasis83 ha pubblicato una discussione in Elaborazioni: Telai Piccoli (ET3, PK, Special, ecc.ecc.)
Ciao Ragazzi!!! Sono nuovo del forum.... Ho bisogno di un vostro aiuto per la carburazione della mia Vespa 50 l del 1969.... Venerdi' ho montato un nuovo gt 102 dr....prima montavo un 75 polini ormai spompo.... Dunque.. ad oggi la mia configurazione è questa: motore 102 dr carburatore 19/19 dell'orto(era del pk del mio povero nonnino....) con getti max 75 e min 45 e filtro originale ridotto a un colabrodo con retina originale... frizione a 4 dischi e molla rinforzata marmitta polini banana rapporti 18/67...(paese di montagna e giro sempre in 2...) Il mio problema è questo: Ho montato in gt e la Vespa è partita al 3 colpo...quindi fino a qui tutto bene...... dopo qualche km ho notato subito che il motore non gira tanto bene...nel senso che quando accelero fa fatica a prendere subito giri....come se fosse magro di carburazione... ho smontato la candela e noto che il colore è nero / unto.... Quando è fredda si accede sempre al primo colpo, ma quando sgaso fa dei vuoti allucinanti... che dopo qualche secondo si risolvono.... ho provato ad avvitare la vite di carburazione e sembra che vada meglio... sono partito da un giro e mezzo e ora sono a mezzo giro.. SEcondo me è un problema di carburazione...però vorrei alcuni consigli da Voi esperti del forum.... Cosa ne dite se aumento il getto del max anche di 10 punti e svito la vite della carburazione di un giro e mezzo??? domanda numero 2.....il filtro secondo voi va bene o devo fare qualche modifica??? o ne costruisco uno artigianale??? MAgari mi dite anche come fare????? Grazie Ragazzi...confido in voi...anche perchè ero convinto che la vespa si alzasse di gas e invece mi trovo a dosare l'acceleratore per non farla invasare..... So che il dr è un gt tranquillo...ma mi aspettavo qualcosa di meglio..... MOD'S ARE BACK!!!!!- 12 risposte
- 102
- acceleratore
- (and 22 più)
Revisione biennale px euro3
ikaro11 ha pubblicato una discussione in Tecnica Generale: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Salve a tutti. io come tanti altri di voi ho un px euro 3 del 2012 che adesso dopo una infinità di prove e tentativi va come dovrebbe andare e come piace a me!!! vi racconto: come ben sapete tanti px euro3 150 cc hanno il fastidiosissimo problema dell'irregolarità ai bassi regimi, si pensava era il catalizzatore, infatti l'ho scatalizzato due giorni dopo con marmitta sito normale, getti be3, 48-160, 100, e ghigliottina 01, e vite carbirazione del minimo 2,5 giri da tutto chiuso, e anticipo accensione messo sulla tacca di riferimento it, era migliorata ma il problema persisteva, le ho provate tutte!!!! alla fine mi sono deciso di montare un gruppo termico 177 e nello specifico un polini 177 P&P con getto massimo 105 e foro sul fitro aria in corrispondenza dei getti, (ovviamente provando altri getti più grandi, dal 108 a scendere con prova candela) adesso la vespa è VERAMENTE perfetta, va che un piacere, sembra un cbr tanto è regolare!!! però adesso mi assilla il problema revisione ed ecco la mia domanda: chi di voi ha fatto la revisione della vespa euro tre con motore 177 e scatalizzata? è passata la revisione? avete dovuto cambiare o modificare qualcosa?, o avete dovuto montare la trementa marmitta catalitica? se si con quali getti visto che il motore è 177? grazie a tutti per chi mi illumina e chi mi legge... buona vespa a tutti.! -
Gruppo Termico Polini per T5
GuglielmoT5 ha pubblicato una discussione in Elaborazioni: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Salve a tutti stavo legendo varie discussione su questo argomento su Vespaonline un ottimo sito devo dire, beh bando allo ciance, mi chiamo Guglielmo e sono un TICINQUISTA....amo il T5 in tutte le sue parti, la mia e unica vespa di sempre! Volevo sapere delle informazioni sul gruppo termico polini modifica per t5, lo vendo senza testata! La mia originale 125 va bene anche senza rettificarla? Devo ampliare il getto del max a 120 giusto? Effettivamente io cerco un po di coppia in più, il polini e più potente in questo rispetto al gruppo termico orginale t5? Grazie..aspetto le vostre risposte e saluti T5 FOR LIFE -
2 o 3 travasi????????????????
joebal ha pubblicato una discussione in Tecnica Generale: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
ciao a tutti!!!possieso una vespa gtr del 1969 e su di questa ho un atroce dubbio: ha 2 o 3 travasi???è un dubbio che mi viene dato che delle persone mi confermano 3 altre invece 2... Sempre su questa vorrei aumentargli la cilindrata magari montando un 170 e magari una buona marmita ma non modificandogli altre cose(ovviamente a parte i getti), la domanda è:faccio male o faccio bene?- 10 risposte
- 125
- carburatore
- (and 19 più)
TECNICA: L'importanza della ghigliottina...
Turbobestia ha pubblicato una discussione in Elaborazioni: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Ciao Amici è un po che sto facendo degli studi sugli Spaco e volevo cominciare a mostrarvi qualche dettaglio: Guardate bene la foto allegata a questo msg, la ghigliottina a sinistra è di uno spaco, quella di destra di un dellorto, gli incavi che vedete sono dei passaggi per aumentare l'afflusso d'aria dopo il getto... la vite del getto regola la quantità di benzina per unità di volume d'aria quindi piu aria passa, piu crea depressione sull'ugello e piu risucchia benzina... Come smagrire quindi la miscela aria benzina per rientrare nelle normative EURO? basta intagliare la ghigliottina nella parte bassa cosi che oltre a risucchiare aria dal venturi viene risucchiata aria anche dal corpo carburatore purtoppo però senza benzina... se vedete la ghigliottina a destra vedrete che l'intaglio è molto meno profondo ed è unico a differenza di quella spaco che sono 3, quando si hanno problemi di smagrimento ai bassi e medi regimi la causa è da imputare a tali incavi (oltre che a tutte le altre differenze di cui vi parlerò in seguito) ciao ciao Turbo -
Pinasco 177 V.I.T. Lamellare al cilindro, è finalmente uscito?
pirrolo ha pubblicato una discussione in Elaborazioni: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Oggi Mi è arrivata questa e_mail dalla Pinasco: GRUPPO TERMICO PINASCO 177 V.I.T. LAMELLARE Il nuovo gruppo termico PINASCO 177 V.I.T. (Valve Intake Transfer), lamellare al cilindro per Vespa PX, è una rivoluzione nel mondo Vespa e si distacca da tutti i kit di elaborazioni costruiti finora per la coraggiosa scelta dei componenti che lo compongono. Il cilindro presenta la nuovissima aspirazione lamellare diretta al cilindro, PINASCO può vantarsi di essere stata la prima casa costruttrice di elaborazioni per Vespa ad aver progettato questa aspirazione già nei primi anni 80. I tecnici PINASCO hanno ripreso tale progetto adattandolo alla tecnologia ed ai componenti dei giorni nostri. Il kit è composto da un cilindro in ghisa speciale configurato per prestazioni ottimali turistiche da tragitto misto. La specifica configurazione delle fasi di aspirazione e scarico è il miglior compromesso per ottime prestazioni e guidabilità su ogni tipo di percorso, sia tortuoso di montagna, sia rettilineo autostradale. Il pacco lamellare è in fusione di alluminio con riporto in Viton e lavorazioni interne per garantire unÔÇÖottima fluidodinamica, le lamelle sono rigorosamente in carbonio di altissima qualità. Nel kit viene fornito un nuovo tipo di carburatore 27/32 a depressione con pompa benzina integrata per garantire in ogni condizione di guida il giusto apporto di carburante senza più risentire di quei fastidiosi vuoti di miscela che spesso portano ad un inevitabile grippaggio. Tale carburatore presenta un ulteriore vantaggio, è privo di getti aria/miscela e la carburazione si regola avvitando o svitando le viti di regolazione del minimo e massimo. Un'altra caratteristica fondamentale è che per montare il PINASCO 177 V.I.T. non è più necessario modificare la valvola rotante come si faceva in passato, nel kit viene fornita una piastrina apposita per sigillarla. Per tornare alla configurazione originale sarà sufficiente smontare la piastrina e riposizionare il carburatore ed il cilindro originale al loro posto, il motore tornerà quello di prima. Il progetto era stato presentato già qualche anno fa, ma poi non fu mai commercializzato, che questa sia la volta buona? dalla foto allegata al messaggio, si nota anche una nuova testa a candela centrale! -
Carburatore 20/20 su VBB1T - configurazione -
Vespa30 ha pubblicato una discussione in Elaborazioni: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Salve gente, posto in questa sezione poichè potrebbe essere una minima elaborazione per una nonna di 50 anni. Volevo sapere se qualcuno ha montato un 20/20 Dell'Orto su una VBB e quale configurazione getti ha utilizzato. Avendo uno di questi carburatori a disposizione l'ho fatto per provare e la nonnetta ha cambiato carattere, va veramente molto meglio, tranne per una leggera incertezza nel salire di giri al primo 1/4 di acceleratore, dopo di che non ci sono problemi, bella progressione e V.Max aumentata di circa 5 Km/H. La Vespa parte sempre al primo colpo, anche se a caldo sembra essere meno pronta a mettersi in moto. Monto 160/Be3/100 e 48/160, vite posteriore a 1,5 giri, filtro aria PX con fori 5 mm. sul max e 3 mm. sul min, marmitta Sito per VBB nuova, candela nuova, bella marrone scuro dopo un tratto di statale fatto sul filo degli 80 KM/H. Aspetto pareri da chi magari ha tentato la mia stessa strada e da chiunque mi voglia dare consigli. Grazie. -
Px 150, Gruppo Termico Dr 177cc e Scarico Sito Plus
finizio81 ha pubblicato una discussione in Elaborazioni: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Sera a tutti un info, dopo aver grippato ho fatto montare un Gruppo Termico Dr 177cc con marmitta SitoPlus il tutto perchè non volevo una roba da competizione ma giusto una spinta in più in salita in due. Questa sera quando il caro amico meccanica quando me l'ha consegnata subito mi è saltato all'orecchio un lieve rumore metallico proveniente dal gruppo termico(o almeno credo), il meccanico mi ha detto che è una roba normale in quanto adesso vi e montato un GT 177 ed e lievemente più rumoroso. Chiedo a voi più esperti o qualcuno che come me ne ha già montato uno se e normale che sia leggermente più rumoroso il Dr 177. Il rumore e lievemente metallico. Lui mi ha detto di aver controllato la biella ed era apposto e non mi ha mostrato alcun altro problema. Grazie a tutti per le vostre risposte..... -
ho messo la Sip Road
greenratt^ ha pubblicato una discussione in Elaborazioni: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Ieri ho montato sul Pinascone 225 la marmitta Sip Road: Racing exhaust SIP ROAD Devo dire di essere soddisfatto,sebbene ieri non abbia fatto molti km. La differenza con la padella si sente veramente molto:nessun buco in erogazione,i bassi sono addirittura migliorati e ed il sound è ottimo.Mi manca di provare l'allungo ma viste le premesse credo che non ci sia paragone con il padellino... -
AIUTO: vespa px perde benzina da carburatore
gava ha pubblicato una discussione in Tecnica Generale: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Ciao a tutti, oggi ho revisionato il carburatore: l'ho smontato, ho pulito bene le varie parti e i getti con benzina con aria compressa e l'ho rimontato. Una volta montato il tutto ho dato una botta col pedale e la vespa è partita. Poi si è spenta e ha iniziato a perder benzina..da lì non si è più accesa e appena giro il rubinetto perdo. La perdita arriva chiaramente dal carburatore. Avevo acquistato un kit di revisione, del quale ho usato solo un paio di guarnizioni nuove. Non ho modificato le regolazioni dei getti. Ho smontato anche galleggiante e spillo per pulirli e forse potrebbe esser lì il problema. Nel kit c'è anche uno spillo nuovo, ma il vecchio mi pare a posto...che consigli mi date? non so proprio che fare anche perchè il mezzo mi è rimasto in campagna, lontano dai meccanici!! -
carburatore per una vespa pk 50 (75)
bag85 ha pubblicato una discussione in Tecnica Generale: Telai Piccoli (ET3, PK, Special, ecc.ecc.)
ciao ragazzi, ho bisogno di un consiglio, ho fatto un lavoro sulla vespa di un mio amico, un PK 50 di quelli senza la pedalina Ho cambiato il cilindro e ho messo un 75, il carburatore credo che sia un 12/12, correggetemi se sbaglio, che faccio, lo cambio? cosa ci metto? un 16/16. Adesso la vespa si accende, pero` sembra piu un trattore che una vespa, in quanto alla massima apertura dell acceleratore va pianissimo, a passo d`uomo DItemi magari anche che getti mettere Grazie mille- 9 risposte
- acceleratore
- apertura
- (and 23 più)
Anomalia alimentazione PX150 MY 2001
doitch ha pubblicato una discussione in Tecnica Generale: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Ciao a tutti, ho recentemente acquistato un PX150 del 2001 con circa 26000 Km. Il precedente propritario ha sostituito la marmitta orginale (Cat.) con una Sito e mi ha detto che è stata rivista la carburazione per otimizzare il funzionamento a seguito dell'installazione del nuovo scarico ma che uno dei getti sostituiti (non ricorda quale) non è della dimensione corretta perchè non è stato trovato. Il risultato è che andando a velocità costante al 75-100% del gas il motore gira regolarmente senza problemi ma chiudendo il gas (es. per scalare marcia) e riaccelerando il motore tende a soffocare come se finisse la benzina ma dopo circa 1-2 secondi ritorna alla normalità. Il problema andando a regimi inferiori al 75% non si presenta. Ho provveduto a pulire filtro aria, benzina e tutti i getti e per sicurezza ho sostituito lo spillo conico del galleggiante. Ho notato che è stato montato un polverizzatore BE5 ed un getto max 102, ho provato a montare un getto max 100 ma la cosa peggiora leggermente. I tecnici della Sito mi hanno detto che non deve essere modificata la carburazione perchè lo scarico è studiato per mantenere il motore in condizioni originali. Ho il sospetto che il problema possa dipendere dalla configurazione attuale di getto min e polverizzatore+getto max attualmente montati, secondo voi? Se montassi un polverizzatore BE3+getto max 100 (ipotizzando che il getto min sia quello originale, purtroppo mi son dimenticato di verificare) potrebbe risolversi la cosa? O è il caso di aumentare il getto min? Dai ricordi molto vaghi del precedente proprietario, è emerso che il getto in questione doveva essere un "62" ma invece è un "60", l'unco getto che ho trovato di questa misura è quello dello starter ma dubito che possa essere coinvolto in questo scenario... Grazie mille per i consigli che mi darete! Ciao ciao- 4 risposte
- carburazione
- getti
(and 2 più)
Taggato come:
Zirri Silent: per ora mezza delusione...
gjespo85 ha pubblicato una discussione in Elaborazioni: Telai Piccoli (ET3, PK, Special, ecc.ecc.)
Ciao raga, da inizio gennaio ho comprato una Silent usata da un mio amico. Lo scarico è ben tenuto, l'espansione non ha neanche un graffio ed è stata usata per poco tempo. Me la porto a casa tutto contento e il giorno dopo decido di provarla sul 102 Polini della Special di mio fratello. In mezz'ora l'ho installata... accendo e mi accorgo subito del fantastico "sound" di questa espansione. Scaldo un po' la Vespella e faccio un giro per provarla. Il motore ha buoni bassi, più del Polini a banana che c'era prima, ma mano a mano che i giri salgono sento l'avvicinarsi di un "buco" di potenza attorno ai 5000 giri (calcolati con apposito programmino). Poi lo scarico riprende e si riescono a tirare 1^, 2^ e 3^, ma 4^ ovviamente no (a causa dei rapporti lunghissimi - 23/60). In salita il "buco" si sente tantissimo, anche in 2^... Allora ritorno a casa pensando cha magari essendo lo scarico fatto per un 130, ovviamente sul 102 non rende tanto; contatto un mio amico che ha un Malox 130, rapoprti 22/63, Proma, ecc, ecc e gli chiedo se vuole provare la Zirri. Lui, visto che non ne aveva mai provata una, accetta tutto felice. Dopo averla montata andiamo a provarla e anche lui nota un miglioramento ai bassi rispetto alla Proma, ma poi avverte il solito "buco"... poi la risonanza fa il suo dovere e tira appieno i rapporti fino alla 4^. La provo anch'io e quoto la sua opinione, notando che il buco è tale e quale a quello del 102 Special, in salita potrebbe dare problemi. Andiamo a casa e rimontiamo la Proma e facciamo la prova con quella. Il buco non c'è e i rapporti vengono tirati completamente fino in 4^. CONCLUSIONE: la Proma va come la Zirri, prenderà al max 200-300 giri/min in meno rispetto all'espansione, però non ha il famoso "buco" che sulle nostre stradine di montagna potrebbe fare la differenza. Dopo tutta questa pappardella (scusate) vi chiedo è normale che la Zirri abbia questo "buco" così rilevante? E' possibile apportare qualche miglioramento senza modificare le fasature del GT? Se vi servono le config delle Vespa usate come tester: 50 Special (Verde) - 102cc Polini (fasature originali) - albero originale - rapporti Polini 23/60 (lo so che sono lunghissimi) - Dell'Orto 19/19 50 Special (Blu) - 132cc Malossi (fasature originali) - albero ET3 originale - rapporti RMS 22/63 - Dell'Orto 24 GRAZIE MANDI -
TEST PINASCO 177 IN GHISA!!!
Ciao a tutti questa estate come molti sanno sono partito per la Spagna con il 177 Pinasco in Ghisa molti erano incuriositi su che tipo di motore si trattasse, Io ed Andrea TC l'abbiamo testato per voi, ecco alcuni dati tecnici: Abbiamo fatto dai 31 ai 33Km/l il motore tira come un dannato nonostante i pesi dei bagagli, montato senza lavori su un motore originale px del 1980 mai aperto con primaria da 22 denti ho toccato i 104km/h di digitale, ha talmente tanta coppia che la 2^ e la 3^ la usavamo pochissimo la 4^ normalmente la ingranavamo a 28km/h di DGT,io sul mio motore ho avuto 0 scadate, 0 problemi, affidabilissimo, Andrea TC ha scaldato qualche volta all'inizio del viaggio perchè si è rotto il carburatore da 20/20, sostituito il carburatore non ci sono stati più problemi ed il suo motore andava esattamente come il mio... lungo il tragitto (a metà Francia) ad Andrea ha cominciato a saltare la 2^ e la 3^ marcia, carico come un mulo ha guidato praticamente facendo 1^ 4^ per gran parte del tragitto, anche Andrea era con un motore vecchissimo. La nostra scelta sull'utilizzare motori vecchi ed usurati è stata fatta proprio per dimostrare che il cilindro non deve necessariamente essere montato su base nuova ma anche su motori con Km e Km, alla fine abbiamo fatto circa 2500km (pochi per una vacanza ma abbastanza per 6gg di viaggio) i cilindri hanno retto benissimo senza nessun problema rilevante, abbiamo provato poi i motori con la testa originale e con quella abbassata da 1mm, con quella più bassa abbiamo recuperato una coppia ancora più marcata ma tale lavoro necessita anche una carburazione ad hok, le alte temperature spagnole non perdonano, abbiamo trovato termometri che segnavano i 39°quindi l'asfalto sarà stato anche 50┬░, i motori nonostante fossero poco raffreddati hanno retto tranquillamente il test infernale. Allego qui sotto alcune foto per mostrarvi la mole di carico al quale abbiamo sottoposto i cilindri Pinasco... Lascio a voi i commenti... ciao ciao Turbo- 140 risposte
problema carburazione vespa 50..che stufooo!
quaros ha pubblicato una discussione in Tecnica Generale: Telai Piccoli (ET3, PK, Special, ecc.ecc.)
La mia vespa 50 (v del 91 a 3 marca) ha un problema di carburazione che non riesco a risolvere nonostante tanti tentativi. I sintomi sono questi: - da fredda parte subito anche senza tirare l'aria - quando è calda fa un pò fatica, devo accelerare e tenere premuto il pulsante dell'accensione per un pò di secondi - soprattutto da calda tende a rimanere accelerata a volte proprio tanto, devo frenare e farla un pò morire sfrizionando per farla calare di giri - quando è calda non tiene il minimo e ai semafori devo giocare con l'acceleratore, sembra che affoghi. -la regolazione del minimo è sensibilissima, si passa da avere il minimo basso a molto alto col la vespa che in folle sale di giri. gli interventi sono stati: - 2 carburazioni da due meccanici differenti - sostituzione cavo aria e acceleratore - rimessi tutti i getti originali - pulizia carburatore - controllo serraggi vari - sostituzione paraolio lato volano La vespa a parere dei meccanici non tira aria da nessuna parte... e va quasi bene.. pazzesco...Secondo me assolutamente no, devo tenerla con il minimo bassissimo e continuare ad accelerare per non farla spegnere altrimenti i giri salgono salgono incontrollati. Andando la vespa non è male, ripresa zero assoluto ma tutta originale i 55 me li ha fatti Idee? un pò di frenafiletti sul collettore? è la valvola che è rigata?- 15 risposte
- acceleratore
- accensione
- (and 22 più)
help!! phbh 28 rd...
vespafrank ha pubblicato una discussione in Elaborazioni: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
ragazzi ho preso questo phbh rd per 40 euro per il mio motore ma non conoscendolo mi spiegate quali sono i getti e se vanno bene?? questo carburatore ha la valvola ovale ed è provvisto di powerjet ma dov'è il getto?? ho letto che per il max si deve fare la somma del getto del max piu il pj! 1 --- che getto c'è li?? 2 --- polverizzatore T264 3 --- 250?? 4 --- max 95 5 --- 90 6 --- avviamento 70 7 --- ?? ? --- olio?? ho mancato qualcosa?? scusate le mille domande ma non lo conosco proprio! grazie a tutti in anticipo- 6 risposte
carburazione phbh 28 polini 177
maxtiesse ha pubblicato una discussione in Elaborazioni: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
Salve a tutti, Avrei bisogno di consigli per carburare il mio polini 177 cosi' configurato : 177 polini con travaseria raccordata ai carter albero anticipato secondo istruzioni polini seguendo il taglio originale Marmitta jl right hand Accensione parmakit anticipo variabile settata coma da istruzioni ,valvola allargata 1,5 per parte , carburatore phbh 28 con : filtro polini a cono , polverizzatore av 264 spillo x2 seconda tacca dall'alto, minimo 62 , massimo 125 galleggiante da 8,5 gr . Vite miscela svitata di 2 giri comando aria funziona correttamente Il motore sale bene di giri, a freddo , parte al primo colpo senza tirare l'aria e il funzionamento sembra normale, ma a caldo e in fase di rilascio tende a rimanere accelerato. Sicuramente aspira aria da qualche parte , ma non so da dove , il collettore in gomma l'ho sostituito perche' l'altro originale polini si spaccava di continuo, ora ho messo il tubo che si usa per le turbine delle auto, molto resistente e che va a forza sia nel collettore che nel carburatore garantendo una buona tenuta.Il motore e' stato rifatto per l'ennesima volta sostituendo carter , cuscinetti, paraoli gaurnizioni etc etc, insomma tutto nuovo, ho fatto anche la prova del tappo dell'olio ma non sputa neanche un goccio di olio, ho cammbiato diverse volta la configurazione del carburatore con diversi polverizzatori / spilli / getti . Non so dove guardare.... un aiuto?. ho gia grippato 2 volte ...sono alla terza ed ultima rettifica . Grazie in anticipo per gli ..aiuti Ciao -
carburatore SI 20/20 D su vespa super 150, come carburarlo?
VespaSF ha pubblicato una discussione in Tecnica Generale: Telai Grandi (PX, PE, Rally, TS, Sprint, Ecc.ecc.)
vivo a San Francisco e in piena crisi d'astinenza di Vespa mi sono comprato una Super 150 del 1966. esteticamente in condizioni molto buone, tutto sembra funzionare a dovere, tranne la carburazione. che sembra troppo grassa. Quando si guida, si ha la sensazione che faccia fatica a crescere, a prendere i giri (più apri e meno va, non esattamente, ma sembra così), le marce le cambi tutte, ma il rumore è "da naso intasato" e quando tiro la quarta sembra che a un certo punto si pianti, anche se la sensazione è che potrebbe andare più forte. Ho guardato il carburatore e ho scoperto che è un dell'orto SI 20/20 D che mi pare non sia l'originale, in più ho visto che alla scatola del filtro dell'aria mancano tutte le guarnizioni (che ho comprato e messo, ma ho subito tolto perchè si inginocchia esageratamente). I getti sono 48 160 il minimo (credo) e il massimo 160. Secondo alcuni dovrei rimettere il carburatore originale, io speravo di cavarmela con un paio di getti nuovi. Dette le variabili, filtro dell'aria che da aperto diventerà chiuso e il carburatore più grande, che misure di getto mi consigliate? Siccome verrò in Italia a breve vorrei approfittarne per prendere quel che serve prima di tornarmene nel Far West. Allego qualche foto, anche della candela, che parla da sola... grazie [ATTACH=CONFIG]55438[/ATTACH][ATTACH=CONFIG]55439[/ATTACH][ATTACH=CONFIG]55440[/ATTACH]- 2 risposte
- carburazione
- getti
(and 2 più)
Taggato come:
